Hi,
I trying to convert video clips to my i.beat move player. There is a converter for this, but works only on windows(some kind of mencoder front-end) So please help me with this painfully command lines on mencoder
Mediainfo says:
Here is the video http://stardust.linuxolution.org/~tolostoi/TEMP/videohelp/11.avi (server is on my machine, maybe not work all the time)Code:General Complete name : 11.avi Format : AVI Format/Info : Audio Video Interleave File size : 21.7 MiB Duration : 7mn 13s Overall bit rate : 420 Kbps Writing application : MEncoder Sherpya-MinGW-20060312-4.1.0 Writing library : MPlayer Video ID : 0 Format : MPEG-4 Visual Format profile : Simple@L3 Format settings, BVOP : No Format settings, QPel : No Format settings, GMC : No warppoints Format settings, Matrix : Default (H.263) Codec ID : XVID Codec ID/Hint : XviD Duration : 7mn 13s Bit rate : 314 Kbps Width : 160 pixels Height : 128 pixels Display aspect ratio : 5/4 Frame rate : 15.000 fps Resolution : 24 bits Colorimetry : 4:2:0 Scan type : Progressive Bits/(Pixel*Frame) : 1.021 Stream size : 16.2 MiB (75%) Writing library : XviD 1.1.0 (UTC 2005-11-22) Audio ID : 1 Format : MPEG Audio Format version : Version 1 Format profile : Layer 2 Codec ID : 50 Codec ID/Hint : MP1 Duration : 7mn 13s Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Sampling rate : 44.1 KHz Resolution : 16 bits Stream size : 4.97 MiB (23%) Alignment : Split accross interleaves Interleave, duration : 26 ms (0.39 video frame) Interleave, preload duration : 523 ms
This is not work well
or thisCode:mencoder INPUT -o OUTPUT -ofps 18 -vf-add scale=128:160, -vf-add expand=128:160:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64
This flipping on video is wrong, maybe for older model of my player is useful, converted videos with command lines is with very bad quality and A/V is not in sync.Code:mencoder -really-quiet in_file.avi -o out_file.avi -ofps 18 -vf-add scale=220:176,\ -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts \ bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64
Avidemux not working well for me, the fps on video is well, but audio not in sync (player works with 18. 000 and 15.000 fps)
Please excuse my bad English
EDIT:
I found the solutionWith this fancy command lines to mencoder, trying many options, but audio/video is still out of sync. In the directory where is the installed windows program under wine (TrekStor_i-Beat_move_AVI-Converter_setup) /home/tolostoi/.wine/drive_c/Program Files/TrekStor/i.Beat move/AVI-Converter was a Converter.ini file with command lines. But still out of sync with my mencoder under debian
With mencoder.exe from AVI-Converter is perfect
Here is the mencoder.exe that work link http://stardust.linuxolution.org/~tolostoi/TEMP/videohelp/mencoder.tar.gzCode:wine MENCODER.EXE /home/tolostoi/11peno.avi -o 11test_1.avi -ofps 15 -vf-add scale=160:128 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=250:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96
The .ini file for someone need it.
Code:1-1-1=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-1-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-1-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-1-1=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-1-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-1-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-1-1=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-1-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-1-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:96:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-2-1=-ofps 15 -vf-add scale=128:128 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-2-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-2-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-2-1=-ofps 15 -vf-add scale=128:128 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-2-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-2-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-2-1=-ofps 15 -vf-add scale=128:128 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-2-2=-ofps 15 -vf-add scale=128:96 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-2-3=-ofps 15 -vf-add scale=128:72 -vf-add expand=128:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-3-1=-ofps 15 -vf-add scale=160:128 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-3-2=-ofps 15 -vf-add scale=160:120 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-3-3=-ofps 15 -vf-add scale=160:90 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-3-1=-ofps 15 -vf-add scale=160:128 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-3-2=-ofps 15 -vf-add scale=160:120 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-3-3=-ofps 15 -vf-add scale=160:90 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-3-1=-ofps 15 -vf-add scale=160:128 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=250:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-3-2=-ofps 15 -vf-add scale=160:120 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=250:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-3-3=-ofps 15 -vf-add scale=160:90 -vf-add expand=160:128:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=250:max_bframes=0:quant_type=h263 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-4-1=-ofps 15 -vf-add scale=176:144 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-4-2=-ofps 15 -vf-add scale=176:132 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-4-3=-ofps 15 -vf-add scale=176:99 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-4-1=-ofps 15 -vf-add scale=176:144 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-4-2=-ofps 15 -vf-add scale=176:132 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 2-4-3=-ofps 15 -vf-add scale=176:99 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=400:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-4-1=-ofps 15 -vf-add scale=176:144 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-4-2=-ofps 15 -vf-add scale=176:132 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 3-4-3=-ofps 15 -vf-add scale=176:99 -vf-add expand=176:144:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=350:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=96 1-5-1=-ofps 18 -vf-add scale=220:176, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=550:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 1-5-2=-ofps 18 -vf-add scale=220:165, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=550:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 1-5-3=-ofps 18 -vf-add scale=220:124, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=550:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 2-5-1=-ofps 18 -vf-add scale=220:176, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 2-5-2=-ofps 18 -vf-add scale=220:165, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 2-5-3=-ofps 18 -vf-add scale=220:124, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-5-1=-ofps 18 -vf-add scale=220:176, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-5-2=-ofps 18 -vf-add scale=220:165, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-5-3=-ofps 18 -vf-add scale=220:124, -vf-add expand=220:176:-1:-1:1,rotate=2,flip -srate 44100 -ovc xvid -xvidencopts bitrate=300:max_bframes=0:quant_type=h263:me_quality=0 -oac lavc -lavcopts acodec=mp2:abitrate=64 1-6-1=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=600:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=128 1-6-2=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=600:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=128 1-6-3=-ofps 20 -vf-add scale=320:180 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=600:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=128 2-6-1=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64 2-6-2=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64 2-6-3=-ofps 20 -vf-add scale=320:180 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=500:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-6-1=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-6-2=-ofps 20 -vf-add scale=320:240 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64 3-6-3=-ofps 20 -vf-add scale=320:180 -vf-add expand=320:240:-1:-1:1 -srate 44100 -ovc xvid -xvidencopts bitrate=450:max_bframes=0:quant_type=h263:me_quality=4 -oac lavc -lavcopts acodec=mp2:abitrate=64
Results 1 to 1 of 1
Less verbose mencoder but WITH status line
By darkpingu in forum Video ConversionReplies: 2Last Post: 8th Feb 2011, 17:58 -
(linux) Problem downloading flv file [solved]
By aboa in forum LinuxReplies: 2Last Post: 25th Mar 2009, 12:56 -
(SOLVED) Need mencoder help, certain files have no audio
By Airjrdn in forum Video ConversionReplies: 16Last Post: 7th May 2008, 21:28 -
Worse video quality on Linux than Windows with mencoder
By chiun in forum Video ConversionReplies: 1Last Post: 19th Dec 2007, 03:29 -
Mencoder 2-pass Command Line to flv
By mrready in forum Video ConversionReplies: 1Last Post: 16th Dec 2007, 03:25
